LogixPro exercises
Shevanel
Mar 2009
US
Hi, I just uploaded all the exercises I have finished for LogixPro and was just curious if anyone might want to check them out. Oh yeah, thanks to Lancie1 :geek: for some ideas on the bottleline exercise. I still have yet to finish the elevator exercise but I am slowly trying to motivate myself to finish it. Anyways, it was fun while it lasted.
Oh yeah, my programs might be a bit messy as I tried to keep out as many as possible errors as possible the more I would think about it the more complicated the program would become. Cheers! :site:
Shevanel, welcome to the forum. I looked at some of your programs. It appears that you are getting better as you gain more experience.
Do you want some feedback (point out areas for improvement) on your different programs? For example,in your Batch Simulator Rung 13, you don't allow Pump 2 to run until Pump 1 is finished. Now what made you think that was necessary?
In real-world batch mixing, as many things as possible are pumped and mixed at the same time. "Time is money" is a common expression that you will hear again, so do not write your logic to prevent two things from being done at the same time, when there is no practical reason for doing that. In the LogixPro Batch Simulation, the instructions do not forbid running Pumps 1 and 2 at the same time. Because both are being metered with flowmeters, they should be started at the same time, and whichever one reaches its setpoint first should stop, and the other should keep running until it is also finished. In other words, they each stand alone, each pumping a different liquid, with different setpoints and different run times. It is much more efficient (in the real world) to pump in 2 or 3 or 4 materials at the same time (where there is no reason not to) than to pump them in serially. Time is money.
I never thought of that and thank you for pointing that out. It's critism like this that makes me think more critically and more advanced. Thank you. If you find anything else let me know. (y)
Hi All, I'm new to PLCs and the Industrial Systems field as a whole. Currently I'm working through the exercises for LogixPro and was hoping I...
3,733
Hi, I'm kind of new here. I am trying to do the Elevator problems but it's just not making sense to me. I am pretty bad at programming so it's...
4,241
Ok, I am looking for criticism of my work on these door exercises. First is exercise 3... It works as it is supposed to so I am looking for...
19,478
SELECTED NEW FILE SELECTED PROCESSOR TYPE SELECTED I/O CONFIGURATIONS IM UNABLE TO CONFIGURE MY I/O’S. I HAVE A PAPER COPY OF A PROGRAM AND I...
81
Good morning, I am currently working on the LogixPro Advanced Batch #2 Multiple Mode of Operation and got stuck very close to completion. Link...
2,242
