Logo rc230 program help
devnul1
Apr 2015
SB, CA
I'm trying to create a simple program that runs like this:
Output 1: ON - 10mins
Out 1: off
delay: 60 seconds
Output 2: on - 10mins
Out 2: 0ff
delay: 60 seconds
Repeat while on.
I've created a program usings Siemens program, but I can't seem to figure out the delays.. if anyone is able to help, i've really been banging my head against the wall on the delay issue.
Thanks,
Devnull
I'm unable to open your program, but have knocked up a very simple solution for you to adapt.
The presets need to be changed (I've shortened them to debug)
Steve
PS. not sure what format you required, so there is a ladder version and a function block version.
Hello Team, I am desperate for some help with an assessment I have as part of a Level 3 general engineering course. I am in a role that is much...
417
Hi all, First, thank you for reading the thread. So I had a task as the following: An up-counter must be programmed as part of a batch-counting...
349
Hi Lads, I want to implement a flood prevention system with my domestic water pump. The intention is to have the water pump cut off on a daily...
1,113
[Update: fixed a typo in the image.] See the image below, especially the blue-ish annotations. The three rungs ending in output coils -( ) are...
17
1,025
We need a Really Simple and Cheap controller that has a display or a Web Interface where we can change some set points. We were thinking about a...
1,075
