Looking for a formula to convert RPM at motor to Hz at the VFD.
jki4x4
Dec 2014
Kansas City
With the givin information I need to be able to determine the correct freq. for the VFD to run at to achieve a certain line speed. Here's the information:
Motor operating at 60 Hz has RPM of 1180
The Gear Box has a 159:1 ratio
The Drive sprocket on the gear box is a 13 tooth
The Driven sprocket has 19 a tooth
The net line speed for the sprocket pulling the 2 strand conveyor link off of the Driven is 67 Jobs per Hour
What is the freq needed for this line speed.
I keep tweaking the formula for each new freq but this results in a fractional number of poles for the original motor when compared to the actual conveyor found in the field. I think I just need a new perspective for this equation...
All the rest of your values are in units of rotation and time.
We have no idea how many revolutions of the output sprocket equals a "Job".
So you need to determine the ratio between a "Job" and the output sprocket.
67 "Jobs" x 4.618 revolutions = 309.406 revolutions per 60 minutes
= 5.1567 revolutions per minute.
If 60 Hz gives you 1180 RPM, through gearing ratios of 1:159 and 19:13, then 60 Hz gives you 10.8466 RPM on the output shaft.
(5.1567 / 10.8466) x 60 Hz means you need an output frequency of 28.525 Hz to get the desired line speed of 67 "Jobs" per hour.
It's late here and I'm running on a lot of coffee and not much sleep so check the math.
Hello All, Please direct me to post to the right page. I am really new to PLC, and want to find a tutor who is familiar with Automation Direct's...
168
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
154
I have Allen Bradley plcs, I have had Circuit breakers and other automation equipment in the past. There's no solid buyers local. How much do you...
227
can anyone has a good program to learn plc programming online. i have the basic looking into improve my skills thanks
163
I want to monitor a couple signals in a place where there is no PLC but there is ethernet. I know I can use an AENTR or Flex I/O and a module but...
21
818
