Looking for a variable speed control for single phase motor(s)
MikeVT
May 2008
Holland, MI
83
Does anybody have any experience/suggestions for variable speed control of single phase motors?
My application is: Control up to 4 - 1/2hp fans (shaded pole motors), via analog output from a PLC.
Additional details: My thought is possibly 1 'drive', with separate overload protection for each motor, if needed, controlled by one common analog output.
I know... 3 phase motors wold be much easier. That's not possible in my application.
Thanks for your help.
Thanks James.
All I can find with AB is single phase in, 3 phase out. (PowerFlex 4).
I did find a hit via google, for Invertek. I could get a 1hp unit, and feed 2 fans per drive. Anybody know anything about Invertek drives?
You can many of the AB drives single phase (even though listed as a 3 phase motor). Contact your AB distributor, they will definitely have a tech. that can help.
https://rockwellautomation.custhelp.com/app/answers/detail/a_id/26098
https://rockwellautomation.custhelp.com/app/answers/detail/a_id/516312
If you don't have a TechConnect contract, all of the PowerFlex Technical Data manuals have the single-phase ratings. The few I have come across in the past were basically re-rating for 50% - 65% over.
It's amazing that whenever someone raises this question, so many people misinterpret what the OP is trying to accomplish and post links to VFDs that can produce a three-phase output from a single phase supply. Too bad that's not what MikeVT needs.
In my post #3 I linked to Anacon Systems Eagle Drive that the datasheet clearly states:
Series # 1S covers six(6) ratings in the power range of 1/6HP to 3/4
HP, all suitable for 115 volts, single-phase input, with 115 volts, single-phase output.
How is that NOT what the OP requested?
Sorry about that, seem the remember we used these drives for single phase machines, I must be wrong..
AB PowerFlex525 go all the way down to 120vac single phase. I just bought one for a project. Part number 25B-V2P5N104. Also has built in Ethernet.
The original poster did mention shaded pole. The invertek units will work with most shaded pole designs. The last time I checked the prices on the invertek units, I decided that it would be much more cost efficient to change to 3 phase motors.
That said there is this thread from 2005 when Ron Doran was alive, discussing this problem. http://www.plctalk.net/qanda/showthread.php?p=200316#post200316 . In post #36 http://www.plctalk.net/qanda/showpost.php?p=200316&postcount=36 a PLCs member claims to have made a single phase motor with a start switch function on a three phase output VFD. Note: he used a solid state relay to avoid an arc at the output leads of the VFD. If it did function, I'm sure that the low speed performance would be very poor.
I've been at my current job for a little under a year and I'm trying to get more into the controls side of things. The hardware used onsite is...
Hi I'm working on a HMI (Ifix version 5.5) which is set up to communicate with an Allen Bradley SLC. So my problem is that a popup screen will...
70
Greetings. I currently have several systems in operation mainly using Aromat PLCs and Beijer Exter HMIs. The HMIs email to VText.com to send us...
66
Hello All, Please direct me to post to the right page. I am really new to PLC, and want to find a tutor who is familiar with Automation Direct's...
509
203
