Looking for details of Comms to a Brother CNC
RussB
Oct 2003
Michigan
2,914
It is a Type TC-R2B Model TC-R450X [FONT=&quot]http://www.yamazen.com/products/brother/[/FONT]
The brochure says that it has Ethernet, the supplier knows little about the communications other than the "Ethernet port is to edit G-Code". They want to communicate via 16 inputs and 16 outputs. o_O
I am trying to determine if it supports any industrial protocols like Modbus TCP/IP or Profinet.
RussB said:
...I am trying to determine if it supports any industrial protocols like Modbus TCP/IP or Profinet.
Russ,
I'm not 100% sure, but it seems as though they are all just communication methods for manually transferring programs and data files between a PC and the machine, using their Brother Comm software.
The advent of Ethernet on CNC machines was mostly just to speed up the transfer of programs to the machine's memory. I don't think many, if any, CNC manufacturers have embraced its true potential just yet? Higher end CNCs can have a PC/LAN card instead of a controller, with proprietary PC software for program transfers across Ethernet, but again, it's just for faster transfer of programs.
I've found this document outlining the steps involved for a slightly older Brother A00 control. The TC-R2B uses a newer B00 control, but I'm sure it's similar?
Regards,
George
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
183
Hello All, Please direct me to post to the right page. I am really new to PLC, and want to find a tutor who is familiar with Automation Direct's...
441
I have Allen Bradley plcs, I have had Circuit breakers and other automation equipment in the past. There's no solid buyers local. How much do you...
255
can anyone has a good program to learn plc programming online. i have the basic looking into improve my skills thanks
189
I want to monitor a couple signals in a place where there is no PLC but there is ethernet. I know I can use an AENTR or Flex I/O and a module but...
21
862
