Low power PLC/Controller
gripster
Dec 2010
Londinium
40
Anyone have any suggestions? Looking at max of 3W about 10 I/O with Ethernet and if possible a safety one at that!
Cheers for any suggestions
I've used some of the small safety controllers to do simple logic AND get the safety features. You'll have to carefully look at the instruction set to see if it satisfies your application. The last one I used was the AB Guardmaster 440C. You can do rudimentary logic. There are others from Pilz, etc.
Thank you for the responses, we really need to keep below the 3w threshold which has eliminated most of the bigger brands now looking at the Automation one maybe utilise a couple in tandem.
FYI the AutomationDirect Clicks have expansion modules. You can add up to 8 modules, per CPU.
Without knowing the exact type of the inputs and particularly the outputs, it is impossible to provide an answer.
Are the outputs supposed to drive something ?
anyone have any experience with very low power plc's? It seems hard to find a plc or programmable rtu that has minimal IO that pulls very little...
6,428
Anyone ever use these? I have been using GE VersaMax Micros but we will be switching to the Yokogawa's soon. Doesn't make sense to me as we use...
1,806
Does anybody know if there's a way that I can have Logix Designer apply the green highlight to ALL elements that evaluate true (not just XIO/XIC...
1,814
Hello there, I need to precisely measure total mass in an LPG tank. The types of sensors I'm going to use are: - level transmitter (without...
1,054
Inductive load: Vacuum Pump motor 115VAC 0.9Watts Resistive load: Heater 115VAC 0.75 Watts What is the best way to control these from...
2,028
