M258 CANopen to J1939 Sensor
GSNITZ
Jun 2017
TULSA
30
Hello All! I'm embarking on a new project and have been searching the forums to assist in what is looking to be a rather challenging task.
We are using an TM258LF42DT which has a Sub-DB9 CAN port. The end device is an automotive sensor that supports J1939. The sensor has a heating element which must be turned on/off based on other process conditions. Once the sensor heater is on, the sensor will start providing data.
The task is to establish bi-directional communication with the sensor; we need to be able to send the sensor a command string (to turn-on the heating element), read the data provided in real-time, and when the process is finished send the same command string (to turn-off the heating element).
Looking at the Schneider documentation, it appears the M258 only supports CANopen; a M241 or M251 required for native J1939 support. I've assembled and read through a fair bit of documentation at this point; I've covered the port itself (Hardware Guide), CANopen Configuration (Programming Guide), and SoMachine Templates (Programming Guide). I've also been researching elsewhere to learn about .EDS files, as well as the differences between CANopen / J1939.
I will readily admit I am out of my depth here. At this point I'm hoping to ascertain whether it is even possible to create a custom device template to communicate with the J1939 sensor using the CANopen port, or if I will need a gateway/translator as a go-between? From my other research, it appears that while they share the same physical layer, the two methods use different approaches for the higher level communication layer.
Thanks!
What I've learned in the last few weeks is that CANopen & J1939 cannot perform direct exchange (CANopen device talking directly with J1939 device) due to differences in the communication layer. The information I found during my research was a bit confusing since they can communicate over the same physical network, and in many cases the information was referencing this type of co-mingling of communication layers. At the end of the day, either a protocol converter, or a PLC change is required to implement these sensors.
@Karsten
Thank you for your feedback. That was actually one of the protocol converters I was considering. I decided to go with a PLC change (M241) instead of a protocol converter. It has been very easy to configure the J1939 parameters with the M241.
i have plc modicon m258 its CANopen bus not running and give status on SoMachine v3.1 red triangle after i make download to it so please how...
1,803
Hey, i'm getting an error when i try to upload a program from a modicon M258 TM258LF42DT using eithernet. i tried using both SoMachine V4.1 and...
1,333
Hi friends, I am AVI , working on Schneider electric make M258 PLC. While communicating it with SO machine software v3.0, facing problem...
1,326
I got brand new modicon M258, with extra DI, DO, AI, AO cards, part number TM258LD42DT4 willing to trade with ControlLogix 5000.
1,326
We are running into some issues with serial communications dropping out after a few days. When viewing the PLC hosted web page, we found the...
2,374
