Mach3 and DL340
djbillyd007
Mar 2005
Sevierville TN
83
This is purely a personal project. I am building a my second homemade cnc router. This time going for a 5 axis. I want to use a plc for external stuff that mach3 doesn't do. tool changer ect.. So, for the fun part. I want to connect an automation direct DL340 to the pc using modbus setup. This is easily done with the DL05/06 plcs. I also could do it fairly easily with a siemens step7 200. But the other challenge I have given myself is to see how cheap I could build this thing. I have 2 of the DL340 on hand and only access to the others at work. My main problem is not being able to find much documentation on the modbus on the DL340. Has anyone actually used the modbus option on this cpu? Experience with mach3 modbus output? I know this will be a challenge but I've got nothing but time on this one. Any help or ideas would be greatly appreciated.
I think that is the 4k CPU for the Automation Direct DL-305 series. I have never used that one. I know the second bottom port can be configured to be a slave on a Modbus RTU network. As long as your Mach3 can be the Master, you should be okay with that.
I did find this Modbus Address cross-reference table for the DL-340 CPU.
http://support.automationdirect.com/products/340mbus.html
Must you use Modbus to connect your DL-305 PLC to your PC? It does have the DirectNet comm option.
Bernie Carlton is our resident AD expert. Bernie, chime in here and help another Tennessee hillbilly.
It is for the DL-305 series. Thanks for the link. I now have it and the port2 setup sheet for the 340. Should be able make an attempt tomorrow. First time I've messed with the 305's in years.
Got it!! It was actually pretty easy once I got all the docs together. Amazing what we can do when following the instructions :). Just got myself a little worried when I was strongly cautioned against using the DL340 by a mach3 person who had problems setting one up.
I wanting to connect a small touchscreen as a remote interface with Artsofts (Mach3 cnc) software. This software acts as a Master and can...
2,052
Has any one gotin mach3 and a ML1100 talking modbus i can get Mach to read and write coils and read contacts in binary format only if you...
2,225
I am trying to help a guy out who has a 10 slot base with this CPU and cannot manage to connect to program this PLC with DirectSoft32. There has...
3,357
Hi i wanted to know any guys have done Directlogic networking using DL 450 Series with DL350 series using the Fa-ISONET?? Currently i using...
3,418
Hello Everybody, We have an DL340 cpu whcih inputs 4-20 ma signal from scales to show the weights. Now this value needs to be subtracted from a...
1,697
