machine data logging
May 2006
huddersfield
67
Hi can anybody advise me on a data logging/monitoring system. My customer requires a data logging pc based system, they have 10 x machines of which they require to record the temperature and 3 x speeds of the machines.The temp can be by a pt100/tc the speeds i can aquire via a 0-10v signal from the drives.So far the systems quoted have been a lot of cash has anybody got any advise on a good reasonably priced system??
Some important questions to ask for a data logging system include:
1) How often are values to be logged? Time-based or value-change?
2) How long do the values need to be stored?
3) What format do you need the values stored in?
4) Reports??
5) How does the PC connect to the data? A PLC? Proprietary PC-boards?
6) Is the data "mission critical"? (I.e., does it require redundancy?)
That said, you might want to consider Inductive Automation's FactorySQL
Hey working on a project where I need to send a String Command to a device in order for the device to perform an operation. It's over Profinet but...
1,884
Hi all, Has any of you got any example of reading data from modbus tcp, using FBD? I am just trying to get my head around, doesnt look like a...
2,574
Hi all, I'm a new user for this Forum. I hope not be wrong a section of forum for my request. I would like to development an application to read...
2,596
I’m using Proficy Machine Edition v5.5 to communicate with a S2K series Drive When online with the drive, I tried to watch the value of some...
3,919
Hello everyone, I've installed 2 hardware limit switches in the DI of an FM 353 as reversing switches for the reference point approach... The...
1,589
