machine edition alarm setup
robw53
Nov 2009
south yorks
515
i am having problems getting my alarms to display on my PV+700, i am creating a tag in the tag editor called alarms, data type:device, and assigning it b3:100 as my alarm word.
in alarm setup im adding this as the trigger, and ive tried the trigger type as both VALUE and BIT, and then in the messages tab asssigned the trigger again, used the correct bit for the trigger value and added my message but still no look, anyone see were im going wrong?
ive seen on another application that the tag has been setup as an analogue with an integer data type
regards
Rob
good question, i am away from work at the moment i am back in 2 hours so i will check that then and post my findings
rob
edit: i have the file at home but it is not upto date but that does have alarms setup to run at startup so i crnt see why the latest one would be any different
OK. If you can post your alarm config, that will help. I've used bit and value types for the triggers, depending on the project. For individual alarms, use a value trigger type with the value of 1 for digital alarms.
I think on the messages tab of the alarm config, you can copy the whole thing and paste it into Excel. I will try it later, but I'm using version 6.
i did a test once back at home and i can get it to communicate with another 1500 with view ME Station on my PC, i browsed the online tags from in processor and found B3:100 and went from there and works fine, i will try that tommorrow back at work, if not i will then post what i have so far.
rob
Hello everyone, I am experiencing a strange issue with machine using a PanelView Plus 7 and a CompactLogix 1769 PLC. I am using FTView ME V13...
350
I have created an alarm list that displays alarms from multiple slc or compactlogix pricessors using ME 8 with a pv+ running version 7.0 The...
4,143
I'm getting frustrated creating arrays of variables in Machine edition. I need to make 2 variable arrays that are 102x2 in size, with varying...
123
I have an issue. I am trying to resolve what logic is in a 90-30 PLC (364 CPU). I have 3 Machine Edition backups with different names. All show...
159
Hello everyone, I am not a programmer, but I can do some simple programming. So now I want the time to be recorded every time a pump turns on. I...
35
2,729
