Managed or UnManaged
controlled
Nov 2005
bowmanville
419
Im currently installing a pc based factory talk view system. The network consists of 3 ethernet networks coming back to an ethernet switch, as well as the pc into the switch. I have read many threads on this forum that suggest using managed switches for plc networks.
What is the difference between managed and unmanaged?
Derek
One main reason to use managed switches is just to block multicast traffic from spewing forth across a larger network. For that, you need to enable IGMP snooping on the switches as a bare minimum
The ability of almost all managed switches now to handle a ring network (STP - Spanning Tree Protocol) is nice too, as it can prevent a total network crash from plugging a switch into itself.
Security is another reason in more and more environments... managed switches usually allow you to lock ports to MAC ID's, and shut off unused ports to prevent unauthorized network taps.
Remote Diagnostics can also be handy, and most managed switches have a web page that can give you information on what ports are active, if there are any detected errors on various ports, etc. Most also have the ability to 'Mirror' any port to another, for advanced diagnostics or protocol snooping.
While I prefer using all managed switches, in some cases it really doesn't make sense. I have a few lines here that have a total of 7 or 8 switches each. On those, the only managed switch is the one that connects the line to the entire plant side network. The rest are just standard switches.
Hi, I am looking for an unmanaged network switch (IP67) that can be powered by POE. Any suggestions?
1,710
Other than Allen Bradley. Who else makes EtherNet/IP prioritized switches? I am looking for 5, 8, 12 Port 1000Base (1 gig) Unmanaged Wago and...
1,628
I want to make an application in C# .Net to read Tags from CitectScada (Local variables, Variables tags, Digital Alarms ...) so that I can process...
1,603
I'm not a network guy, but I play one on TV. So, I can ping my unmanaged switch in the control panel only after a power cycle. The PLC and HMI...
2,597
Have a long rung from PC to PLCs. Bought a X101-1 switch to convert Ethernet (Profinet) to fiber. (X106-1 at PLCs end). The only configuration is...
1,924
