Maple systems HMI remote access
nhermanson
Mar 2011
Central Iowa
I've been using AD C-more EA7 HMI's for the last 7 years. They work well for most of what I need, but I need a little bit better data logging / trending. It appears the trend line is not greatly improved with the EA9 series.
What I want to log/trend doesn't require a complete SCADA system and I'd rather not run a separate PC for just that. And I'm cheap.
I'm contemplating buying a Maple System's HMI, but I'm curious for those that use it, is remote accessing it from an I-Phone as easy as the C-more display?
I feel the same about the CMore logging and display. Its pretty lousy.
I am looking for a good way to get logged daily data from CMore to customer too.
Take a look at a Red Lion Data Station Plus. It has been a few years since I've set one up but it can be added in for just data logging. You can do remote access to collect the data files and not need to change the operator interface. Less confusion on their part.
I know what you mean about the trend screen on the AD box. If the actual trend display is less of an issue than having a good data file just add the Red Lion.
Have you considered the EZTouch HMI from EZAutomation.net?
http://www.ezautomation.net/ez3series/ez3series.htm
For data logging, you can store locally on a USB or Micro SD card, but with the free file manager utility, (http://www.ezautomation.net/ez3series/pdfs/file-manager.pdf)
you can take that data and send to a network or PC. The remote app for the iPhone works in the same fashion as C-More except you can also see data tables based on values you are logging.
http://www.ezautomation.net/apps/index.htm
You have to have a VNC client to remotely access the Maple, and you can't get the data log remotely without a PC. BTW they're rebranded Weintek HMIs. We made the mistake of buying Maple HMCs (rebranded Renu) and their tech support knew next to nothing about the software, we lost 2 months until we finally contacted Renu and they solved the issue immediately.
We use Maple System for all of our Remote Locations, they are easy to use, and they work very well for "Remote Access". We do this so that management can log into each location with their smartphone, internet connected device, and see in real-time what is going on.
I highly recommend Maple System!!
They have "Tag" based drivers and Modbus IP for almost any PLC you might have.
If you use VNC it opens a copy of the HMI on your cell phone screen and you take control of the HMI. There is a bit built into the HMI that will tell you when it is being accessed by VNC in case you want to limit access.
hello, I have a Maple Systems HMI5103L currently programed and running in conjunction with a AB 2080-LC50-24QWB. everything works fine data is...
723
Hello friends, I’ve recently started learning about PLCs and HMIs after I acquired a Wago 750-871 with one digital input card and two digital...
20
5,612
Hi Everyone, Customer has an existing Maple Systems HMI Model HMI5104XH connected to a SCADAPack 350 PLC that I am working on. I was able to...
1,714
I currently have a Maple Systems HMI (HMI5070P) communicating over Serial DF1 to a MicroLogix 1400. The problem I have is that the HMI will not...
2,097
Hey guys, I am fairly new to industrial communications. I recently got into a project in which I have a new Rx3I with a CMM002 module that I am...
1,630
