Marquee / LED Display (cheap and easy)
swapped
Mar 2010
nowhere
28
Hi Guys,
I'm looking for a single line display that has 4" or bigger number with a minimum of 6 digits. I would like this to be ethernet capable and easy to interface with a control logix. And the final requirement - has to be cheap.
Have you guys used anything like this? Any recommendations?
I like the InViews but just dont have the budget for them on this little last minute addition.
The cheap requirement is what hurts you. The best thing I can think of for a Ethernet to serial converter is Either a redlion DSP or maybe a new 304k2 , or a Real Time Automation 435. Either one you can be up and running in less than an hour. The Red Lion has so much power that you can do a lot of things with it.The RTA is fall off a log easy. Is 15 minutes you can be running. Having never touched the RTA I had it up and running in 15 or less.
I’m attempting to send a temperature from a SLC-5/02 to an EZiMarquee display. The vendor said to use a MSG instruction to send the data to the...
116
Hello Everyone, Does anyone have any suggestions or experince with a message board that could read a tag from a PLC, or have a PLC send a...
694
I am controlling an EZMarquee display (EZMR-2L10C-E) by EZAutomation with a L82 AB PLC over ethernet. According to their installing/setup guide...
2,063
Hi all, Looking for recommendations on a marquee display. I've used Uticor tough marquees before with good results, but they have quite a long...
22
5,173
I am trying to set up an EZmarqee with a Siemens ET200sp CPU, CM profibus and TIA v13. Using the DPWR communication block, it has an error of...
1,810
