Mass Flow Meter Brands
I am interested in using Mass Flow Meters for either Natural Gas or LPG. In fact I would like to be able to swap back and forth between natural gas and LPG with a minimum of fuss. Ideally I can just select which gas via my SCADA PC and the S7400 PLC can do any scaling adjustment that might be required to calculate energy consumption in megajoules.
Any suggestions about a brand or model of mass flow meter would be welcome.
Different SG
As far as i've ever seen, the thermal mass flow meters need to be calibrated with the SG of the gas, so you would need to have 2 separate meters. Now, you may be able to apply a correction factor in the PLC. Id imagine you would need to work with the vendor to get the required change, and that it would be more complicated than just a simple change in scaling.
Dear All, I need a sample PLC program to count the output pulse of a mass flow meter so that a specific amount of mass (for example 100gm)can be...
173
I need modbus communication tool for Yokogawa Rotamass Flow meter? can any one help me.
990
Dears, I need to add Siemens SITRANS FC430 to the existing PROFIBUS on the machine. I have downloaded GSD files, but while trying to update...
2,562
I was trying to configure a Micro Motion gas flow meter today. When plugged in with HART, it shows itself as "1700 Analog Mass Meter". We want...
2,596
Hi all, I had trouble with commmunication between Mvi69 and mass flowmeter (micro motion-emerson). I configured Mvi69 is master and mass...
3,388
