Master K Plc
master k plc
i need to make ON/OFF in force by pc
i use kgl softwear
thkx hesham
and it's nice to meet one from my country
Amr
in your KGL-win main menu you should select debug menu,From which you should enable I/O Forcing by select the function "Force I/O enable" from this manu.
Then also from the debug Menu wou should select the option "set forced I/O"
chose the bit you want to set on/off then press OK.
Try it and let me Know.
Remember you must be connected to your PLC .
Best Luck beerchug
Hi guys, Just wondering if anyone has tackled an issue similar to this before: creating a redundant master on Modbus so I can have a redundant...
453
Hello parky, goghie, Brian and all of you who kindly come to help when I get stuck. I cannot look into the clock issue that parki has written for...
871
Hello all. I am purchasing a CompactLogix to use as a server which will host 4 other PLC's (2 ControLogix, 2 Beckhoff) and a Fanuc RC. The current...
931
Hi Guys, Here I have started to work on some difficult task, I hope I will get solution here. we have ABB CI-840 Master IO Module needs to be...
607
Hi Guys, Here I have Started to work on some difficult task I hope I will get some solution here. I wanted to communicate ABB CI 840 IO Master...
923
