master moeller PLC with ET200M siemens Slave
Nov 2007
amman
Dir all,​
I am trying to configure moeller CPU XC101 with master profibus XIOC-NET-DP-M to communicate with slave profibus station from Siemens "Distributed I/O System ET 200S":​
So the hardware consists of:​
* Master station "Moeller":​
· XC101 CPU​
· master profibus XIOC-NET-DP-M​
* Slave station "Siemens":​
· ET 200M interface module "6Es7 153-2BA00-0XB0"​
· Digital output card "322-1BH01-0AA0"​
I downloaded the GSD file from Siemens web site . My entire configuration don by Xsoft program.​
Notes:​
· I configured CPU XC101 to communicate with profibus gateway Swire-GW-DP correctly.​
· The slave station can work with Siemens CPU without problems.​
I hope you can give some advices,
Hi i using Kinetik 300 2097 driver control by EIP with using move absolute and incremental for motion , but i want to add same driver and motor as...
51
hello s7-400h and wincc are connected to each other via Ethernet. I need help on how to do time synchronization
54
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
231
I have to start out by saying I am not a PLC programmer and I have basic programming skills but mainly use software as a troubleshooting tool. I...
135
Does anyone have an example project of the cm ptp ET200 SP HA with 410-5H DCS (PCs7 9.1 SP1) for MODBUS MASTER/SLAVE communication ?
132
