MASTERK instruction help
Aug 2021
ohio
I have a masterk 200s and i am upgrading to a productivity 2000 from automation direct The masterk uses a PUT/GET instruction and i cannot figure out what to use as an alternative. Attached is an image of the original program and an explanation of how it works but how would i re write this in newer software that does not use PUT/GET? I'm lost at this point. the analog card is attached to two loadcell transmitters.
PUT & Get put or gets data from shared ram i.e. special modules I suppose it's the equivelent of the Mitsubishi FROM/TO instruction that read or write to the buffer memories of the special cards like analogue modules or communication units.
Hi all. Never really noticed, but I started double checking operands in the CPT instruction. I found if I have the expression N7[37,1] - N7[35,1]...
150
I'm trying to dig to the source of a minor "recoverable" system fault throwing a fault light on a machine that has been confusing my operator...
127
143
Does this instruction calculate values during a single scan, or does it require number of scans based on element count in the array? For Example...
138
Hello All, Was hoping I could get a little help with Modicon ladder logic. This is the first time I have seen Modicon logic and currently trying...
325
