francevendee Member F Join Date May 2005 Location Wales Posts 48 May 25, 2005 #1 I need to load Medoc under Windows XP Any help out there?
Unregistered Guest U May 25, 2005 #2 Hi francevendee If you are using the Dos based Medoc, then you can not run under XP. You will need a dos prompt (MSDos or winxx-win98) Dariusch
Fi_C Guest F May 25, 2005 #3 using the command prompt. assuming medoc is located at C:\medoc the command line should read C:\medoc\medoc.exe e3f12 that works a treat
francevendee Member OP F Join Date May 2005 Location Wales Posts 48 May 25, 2005 #5 The medoc is on floppy. How do I load on to laptop in XP?
Fi_C Guest F May 26, 2005 #6 Just copy all the files from the floppy to a directory on your laptop. make sure that all hidden files are copied accross too
francevendee Member OP F Join Date May 2005 Location Wales Posts 48 May 26, 2005 #7 Done all that. Problem I had was very small screen. Found solution presseing ALT-H when package opened sorted the problem. Any way thanks all for advise.
