Melsec FX3U Ethernet connect to E1071 HMI
nvanzyl
Jan 2011
Pretoria
Wonder if some1 can help me.
Im busy with a project and using a FX3U plc with a FX3U-ENET-L ethernet controller connected to a Beijer E1071 HMI.
I can not get them to communicate for some or other reason. Im not sure if my ports are correct or if im using the wrong protocols. HOpe some1 can help me.
Checked on the Mitsubishi web and found a document but this does not work for some or other reason.
Thanks for the help.
Nic
You need to open ports in the ethernet module in order to get communication up and running. If you open the driver help (Help -> Controller Help) there is a section that explains the necessary settings.
//Supporter.
Thanks supporter.
But i cant get it to work. Im using a FX3U-ENET-L controller which means i have to use the FX configurator EN-L software.
Ive tried using the TCP and UDP but nothing is working. When i set up the melsec connection i can program the PLC via ethernet. That works perfectly.
Hope you have another tip.
Thanks,
Nic
try updating the driver on the E1071 to V4.13.03....this solved my problem, also check your peripheals all macth eachother.!
i`m having a problem at the moment where i`m connected to the E1071 via FX3U, only the connection is slow and the HMI freezes?
any ideas on this?
Dear all, Hope all will be fine.I am here with a problem. I have to Program and configure the Mitsubishi PLC Melsec FX3U-80M. i am using GX...
4,002
I have a system that I am trying (desperately and blindly) to get running with 3 Melsec FX3u PLC's and a GT1575 Touch screen. I have mounted 3...
2,101
Hi everyone, I have a small project for an industrial site entry gate system. It's running on an old Melsec PLC, and I have a new Shihlin PLC...
141
Anyone have access to Melsec Medoc plus 2.31a that can either open a file (.pcd zipped in link below) and send a PDF/screenshot of the ladder, or...
387
Hello! First time poster and a big PLC newbie so I am looking for some backup here. I have an old Mitsubishi FX-48MR that lost its program...
521
