Melsec Limit torque during position move
sawyer65
May 2016
Auburn,AL
21
Hi:
I am working with machines that presses flares on steel brake lines.
The lines are clamped between a stationary die and a moving die. There are 2 moves for the dies to close, the first move is a position move which brings the dies within 2mm of closing, there is a v shaped guide on the moving die which aligns the tubing with the groove in the dies, the second move is the torque move to hold the tube during endforming. Occasionally, one of the flare nuts on the tubing which is supposed to be push back out of the way, ends up on the wrong side of the v shaped guide and between the steel dies. This creates damage to the dies and the ball screw creating the linear movement of the moving die.
Is there a way to limit the torque during the position move then increase it again before the torque move?
PLC:Q03UDCPU
Motion:Q173DCPU
Amp:MR-J3-500B
Motor:HF-SP352B
The instruction manual for that servo amp mentions a torque limit on page 1-1, but I am not sure that is what you are looking for.
Hi everyone, I have a small project for an industrial site entry gate system. It's running on an old Melsec PLC, and I have a new Shihlin PLC...
132
Anyone have access to Melsec Medoc plus 2.31a that can either open a file (.pcd zipped in link below) and send a PDF/screenshot of the ladder, or...
385
Hello! First time poster and a big PLC newbie so I am looking for some backup here. I have an old Mitsubishi FX-48MR that lost its program...
518
Hi I have a Melsec FX1S-20MR, which has been programmed. I would like to copy the program to a new FX1S-20MR? What are the possible ways to do...
623
Hello parky, goghie, Brian and all of you who kindly come to help when I get stuck. I cannot look into the clock issue that parki has written for...
859
