Memory card unformatted
shoeb
Sep 2008
NAGPUR
When i insert a memory card (2711-NM232)into panelview 550 standard terminal,message display in panel view "memory card is unformatted". What can i do?
this may or may not work for you.
Try making a folder
Rockwell Software>RsViewME>Runtime
It's a PV550 Standard terminal; the RSView ME runtime folder is for PanelView Plus terminals.
Your terminal may be so old (prior to firmware version 3) that it will not support the 2711-NM23 card, which uses "ATA" disk access format instead of the old "Linear Flash" format.
Try putting the card into a laptop's PC Card slot and formatting it in FAT16 mode.
My panelview 550 standard terminal firmware is 4.41.
Supposing I want to be put a TIA Portal Project "executable image" onto a memory card (e.g. see picture). The reason for doing this is so that I...
386
Hi , we try to get a CPU 317T-2 D back to life,memory card was defective and with some resets we have only sf light red flickering we...
28
742
S7/TIA v18: Status Message "Insufficient memory space on the memory card"...... Hi, Please can anyone help me with this? I've been trying to...
27
2,420
I am wondering if there is any way I can set a bit in my PLC if the memory card program and the controller program are not the same. The reason...
1,737
I have a Panelview 550 (2711-T5A3L1 Series A Rev D Frn 4.00) that I'm attempting to save its existing program to a memory card but it says the...
1,348
