Metal Object Detector (direct contact)
barryoc
Nov 2009
Kilkenny
148
Guy,
I looking for a sensor that I saw used on a packaging machine. Plastic was shrunk onto the packaged object, but it the plastic was not present a "probe" made contact with the metal package and the shrink process did not occur.
I remember that touching the "probe" that made contact with the metal package resulted in one getting a slight shock.
Can anyone guide me to what type of sensor this was?
Regards,
Barry.
I don't know of a supplier, but I have made my own version of this by using a small 12 volt DC power supply with a DC relay wired in series to the probe. When the probe makes continuity it closes the relay to provide a signal.
Thanks mendonsy,
I will work on that idea.
From memory the unit I am referring to had a din rail mounted "controller" that supplied the lead to the probe, and when a short to the metal container occurred the "controller" supplied the input to the PLC.
Many thanks folks.
I am looking at an application where I will need to detect small hairline cracks in stamped metal parts. The sensing will need to be done in the...
1,156
Good Evening , We had a Mettler Toledo Safeline Metal Detector acting unstable last week . We brought Mettler Toledo in to look at it ...
843
Currently my company has a MT metal detector model V4 that has been down for the better part of a month. The metal detector is giving a F06-5 IO...
3,135
Good Morning , We have a new Fortress Stealth Metal Detector. About 30' away we have a machine with motors and solenoids on it , Whenever...
2,210
Good afternoon all, hope everyone is doing well. I have a mill cutter application which mills into our iron casting part. I am using duct hose...
2,405
