Micrlogix 1200 PID and a RedLion HMI
MATT116
Dec 2009
Dallas, TX
330
Setup:
1762L24BXBR SER C REV B FRN 12
RedLion G306A000
I'm talking to the RedLion DF1 Full Duplex through the Prog/HMI Port on the ML1200.
My customer wants to be able to tune the PID from the HMI.
Since the RedLion cant directly access the PD file created by the ML1200 I have a MOVE instruction like N7:15 > PD9:0.KC
(N7:15 being the integer the HMI writes to). This works fine but if you go online with the PLC and tune the PID the MOVE instruction overwrites any changes made. I would like for the changes made to PD9:0.KC while online through the PID "setup screen" to update N7:15.
It seems like this should be easy but I cant seem to figure it out. Any help would be greatly appreciated.
You can put a toggle bit in that when you are online with the PLC you toggle this bit and the HMI will not over write the data. Then you are not online the HMi be the master and will copy to the PD file.
dear , I am writing a program for 1200 plc for printing using AWA instruction it is printing correctly but data words values are not coming...
1,438
Hey guys, I am facing a weird issue with a micrologix 1400 series PLC installed in my facility.The IP address of the controller is set to...
1,745
Has anybody used a MLX 1100 with a RSview 32? If so how did you set up the drivers? My counter part is the HMI guy I am the Logix geek. So I...
2,239
Hello, I have a question about an encoder that has absolute measurement. Specifically, it's the Lika SMA5, which I would like to connect...
235
68
