Micro 1000 Analog
Feb 2004
Idabel, Ok
390
Just wondering we`ve used the 2 current inputs on the AB Micro 1000 anl. Can we put a 500 ohm resistor in series with one of the 0 to 10 inputs and get 4 to 20?
Not Series
Put the resistor across the 10 volt input so the input is reading the voltage across the resistor. A 4-20 mA signal will produce 2-10 volts at the input.
Not Series
Newbie here. Went through the bouncy analog signal threads for SLC 5 series and got some good tips, but I also have micrologix that doesn't have...
2,986
I am using a Micro logix 1000 with and analog input of 0 to 10 What I want to do is to compare the analog input with a present value. and then...
9,256
Guest
G
I have a micrologix 1000 that I cannot seem to connect to. I don't think the com board is bad but I just cannot seem to connect. I am using Links...
2,513
Hi all So I made this PLC learner box with 6 toggle switches and some push buttons I have it all wired up and all set. However I am having a...
1,440
Hi everyone first day first post. I have a question? Can someone tell me the difference between a micro logic 1000 L10BWA & 1000 BXB? I know the...
1,310
