Micro 820 communications
Another possible way to see IP on a Micro 820 is with a 2080-REMLCD connected to the serial port. The default serial port settings in a new project support the REMLCD but settings could be changed or the port disabled. Menu navigation is similar to MicroLogix 1100/1400: Menu -> Advanced -> ENET Cfg ->
Edit - the REMLCD also has a USB port that will let CCW reach the PLC, IF the PLC serial port is setup to support the REMLCD
I’m running a micro 820 to measure a tank level, then turning on equipment at certain levels. I have an analog input (4-20) that I’m storing and...
295
Hi All, I came up with this for ramping the PWM pin on the micro 820. I'm new to ladder logic so I am not sure if this will even work? Once...
371
The micro 820 is visible in RS Who when I configure my Ethernet to capture the random IP. I am getting an error when following the steps below...
986
Hi! I need help converting an old MicroLogix 1100 project to Micro 820. Project Details I have an old MicroLogix 1100 program that has been in...
486
