Micro 820 to other Micro 820's?
Racer5039
Oct 2014
midwest
77
I am looking at a project that would use Micro 820 to monitor building static PSI, zone temps and some faults on 5 or 6 AHU's. My question is, Is there a way that I can message all other 820 at the same time? Things like Zone temp may be wired to one PLC but used in more that just that one to control the temp's. Building static PSI also. Exhaust fans may be controlled by 3 of the 6 PLC's. I'd like to have that data point in all.
I have looked over the post's a search located and didn't find much that helped.
If someone could point me to a tech note or something in the Knowledge base, I'd be very grateful.
I’m running a micro 820 to measure a tank level, then turning on equipment at certain levels. I have an analog input (4-20) that I’m storing and...
291
Hi All, I came up with this for ramping the PWM pin on the micro 820. I'm new to ladder logic so I am not sure if this will even work? Once...
366
The micro 820 is visible in RS Who when I configure my Ethernet to capture the random IP. I am getting an error when following the steps below...
971
Hi! I need help converting an old MicroLogix 1100 project to Micro 820. Project Details I have an old MicroLogix 1100 program that has been in...
481
