Micro 830 RTC module setup
EnviroService
Jul 2016
Gold Coast
Hi all,
I have a AB Micro 830 - 2080 LC30 24QBB w/ 2080 MEMBAK RTC plug in module installed.
I am setting up a program where I need an output to turn on at 1am and then turn of 1min later (I have already got the TOW timer and input all the time data to turn on my output) This is already sorted, but the question is do I need to program the RTC read instruction to read the data from the module or will it automatically do this when i input the data to the TOW instruction?
EnviroService
I have not used an RTC module, but with other plug in modules you need to download the UDFB and sample code from Rockwell. FREE.. Then import it to your project. There will be step by step instruction with the UDFB download. The FB itself when added to the project will define a plug in module slot and maybe some configuration parameters for the module.
Then your in business.
As long as the RTC has been set correctly to the current date/time the TOW will know what the Date/Time is.(If you are using the MEM-Module be sure to use it also as a program/load device) will save you from a problem later??????
Let me warn you about using the TOW functions you can not cross over the "Midnight" time line to control an output, it would take (2) TOW to make that work correctly.
Hi Guys, Is there any way to get the real time clock datafrom the PV300 to the Micro 830 ? I have figured out how to communicate from the PV to...
3,046
I have the Allen Bradley Micro 830 and I am trying to setup a daily and weekly event that occurs at a certain time. It looks like the Micro 830...
2,698
Hello friends We communicate between Micro 830 and a card that control DC motor via modbus RTU. We do not have any problems in communication. But...
1,524
Hi, Its possible communicate between kinco hmi (mt4404t) and Micro830 through a serial line ( rs232/485 ) ?
1,562
Customer has a Micro 830 (2080-LC30-16AWB) and a Panel View component C200 (2711C-K2M). They want to add remote connectivity. I was thinking of...
2,701
