Micro-logix 1200 Program files
fishenguy
Nov 2007
WESTERN PA
125
Could someone answer a pretty simple question for me.
Can you have more than 1 ladder in the program files for a micrologix 1200 program?
I wrote a program with 4 ladders in the pojects file tree.
The program verified and downloaded to the processor.
But now the pocessor won't scan anything but the Main Ladder (#2).
There are true rungs in the other files but the outputs aren't coming true.
Thanks, Dave
You have to use a "JSR" instruction to run any subroutine other then Ladder 2.
See picture below for an example.
I lost the manual for this machine built in 2003 and need to put it back together. I have the Micrologix 1200 and PanelView 300 Micro programs...
1,780
What type of internal memory does the MicroLogix 1200 Ver.C have? In the documentation, there is only an internal non-removable battery for the...
1,590
I have several Micro Logix 1200's that are bad. Looks like fine metal dust has gotten between the lower board and the plastic outer shell. There...
3,259
Need help a source code to make timer display into hour:min descending from a time of delay 1 sec base timer. Thanks
22
5,928
Hi, I'm using RsLogix 500 micro starter edition with a micrologix 1200 plc. I want to use a counter where I can change the preset via variable. I...
3,682
