Microcontrollers: Where's a good starting point?
Russ
Jun 2002
Ohio.. Go Bucks!!!!
261
I've been interested in these things for a long time. The problem is that there are so many different kinds and I'm not sure where to start.
I'm leaning towards the pic 8051's, but I think those are now really old. But it might not matter because I don't know jack.. .
Anyone?
Advice
In my humble opinion, your best bet is to obtain a subscription to a magazine that I hold to be the bible on "Fun" applications of all things electronic, including microcontrollers. I remember seeing a number of tutorials related to microchip PIC's and the PICAXE as well as others. You have many choices of programmers and programming languages as well. I find the magazine and their resources splendid for all levels of hobbyist/inventor/engineer.
http://www.nutsvolts.com/
The quick answer is that each microcontroller had a purpose and each manufacturer created a version for themselves or to compete with other manufacturers. The issue is that even though some are deprecated, they can still serve a purpose.
Be careful....if you have any free time now, you won't after you catch the microcontroller "addiction" :) Enjoy!!
More resources:
http://www.hobbyprojects.com/pic_tutorials/introduction_to_pic.html
http://www.sparkfun.com/commerce/categories.php
http://www.jaycar.com/
Parrallax Inc. has chips & boards that can run on Basic,Java,Spin (Multi-Core), or somthing called SX I guess a "C" like structure. Anyhow Lots of fun. I started with the cheap ($99) Basic Stamp 2 & "Board of Education" kit since I was familiar with Visual Basic already. It is a 20 Mhz.8 bit processor, 16 I/O with RS232. Kit comes with hard copys of instructions & software. I think you can get these at Radio Shack as well. Prices have gone up it seems.
BD
This forum is not really for Microcontrollers even they have many common things with PLCs. You probably should try something like http://www.electro-tech-online.com/
As for devices - I prefer Microchip PIC - cheap, easy to program, free development software and demo applications.
Wide range devices from 8-pin/8-bit up to powerfull 32-bit chips with variety of periferals available
For tutorials start here: http://www.winpicprog.co.uk/
benji has the right idea.
The whole point of learning how to use a microcontroller is to get down the assembly language and the registers.
AVR is a good place to start.
Some people like microchip but I think the instruction set of awful.
Rabbit semiconductor/z-world has some nice kits.
There isn't much point in getting something that can only be programmed in basic. We have VB for that.
Porting forth to an AVR looks like fun
http://amforth.sourceforge.net/
Your eyes will be opened when you get down to the registers and assembly language on a microcontroller.
Yeah, That would depends on your target application...
many starts from PIC but its advantage (can also be its disadvantage) is its small list of commands.. I have started with Zilog then PIC then Motorolla...
I find there are many libraries and online resource with PIC and many Simulators/Emulators available (very impt)..
but when i tried to port my applications from others into PIC then i get twice or more the size than the other microcontrollers...
Never tried AVR Though...
I've used PIC, PICAXE and Atmel. If you're learning from scratch I'd suggest starting with something like the PICAXE since it's simple and is really designed as a learning tool with the ability to be used in some advanced applications. The PICAXE uses BASIC, which I think is both good and bad. Good because it provides a powerful, yet simple instruction set. Bad because the majority of uCs use C or Assembly and BASIC can teach you some bad habits. To get your head around uCs the PICAXE is fine, once you progress a little further, I'd move to something like the Atmel AtMega or AtTiny series.
You could have a look at www.splatco.com The have rs 485, analogue, can go up to a tonne of I/O. Very easy to use, a basic deveolpment kit with cable, 16 I/O, software, assembled, and tutorial for around $100.
edit: bad splelling
there are a ton of great micros out the...all of the above, but in my opinion I also agree with products from Parallax. they have the most descriptive easily attainable, mostly free documentation out there, along with excellent support forums. Theyll get you up and running quicky without much confusion, then you can move on to others
the parallax might be a good starting point. Once I get comfortable with them then move onto the more challenging languages and controllers.
Check out the arduino micro controller.
http://arduino.cc/en/Main/ArduinoBoardDuemilanove
They even wrote an article about it in a recent wired magazine.
The harware design and software is open source.
I wasn't able to get the software to install on vista at first. I was able to look at the source code and add the appropriate registry keys in vista so that it would install.
How cool is that?
Hi everyone, I am an electronics technician that have been given a tutorial, and I would like some help: I have to interface a microcontroller to...
1,467
Good afternoon! Small bit of background: My company manufactures small assemblies with integrated solenoids and pressure transducers. To make...
3,522
In another thread I asked questions about problems I have had with AB Panelview. I have long felt that it might be cost effective and offer more...
3,707
Do you have an experience with microcontrollers (PIC, AVR) in a hostile industrial environment. Are they apropriate to work in a place with a high...
3,695
Does anybody know how to build an interface from DF1 to Ethernet using a rabbit Microcontroller? Do you know where I am able to obtain DF1...
1,881
