MicrolLogix1500 and ethernet
Aug 2002
Manchester
527
Hi there
A customer of ours wants ethernet capability on a machine we're supplying. We, however, want to use a ML1500.
Is there anything available to permit this or do I have to upgrade to SLC 5/05?
I have about 38 machines with the Micrologix 1500 and the
1761-NET-ENI on our network. Let me know if I can help.
Thanks,
Bob
Hey Bob
Not having any luck connecting a MicroLogix 1500 and the 1761-NEt-ENI. Use the Net utility to set up an IP address in the 1761... That worked ok. In RSLinx Clasic Lite the 1761 comes up as unrecognized even though I have installed the lastest EDS files, I have version D of the 1761. Also are you abel to program a ML1500 through a 1761-NET-ENI. I have found info on AB that says messaging only and other places that say it supports programing?? Anything special I need to set up on the 1761 or the ML1500 to get it to recognize each other?
Thanks Jeff
WAG: I had that problem with a series d unit recently that was connected to a SLC with the serial port set to 38.4k baud. I finally found a technote that recommended changing the baud rate in the NET-ENI configuration from Auto to the actual baud rate. Once I did that (using the configuration utility), I was able to see the processor correctly in RSLinx. Before I did that, sometimes I would get the red x, and other times I could see the NET-ENI in RSLinx.
EDIT: I believe the comment about "messaging only" is meant to let you know that you can't use it to control Ethernet I/P based I/O. We use the NET-ENI all the time to program Micrologix and SLC processors, as well as connect to HMIs and other processors. I have not, however, used one with a ML1500.
Paul
Which driver are you using in RSLinx that shows the 1761-NET-ENI as "Unrecognized Device"; the Ethernet Devices driver or the EtherNet/IP driver ?
Does the question mark icon also have a red X over it ? That would indicate no connectivity at all, rather than an identity problem.
Try two simple connectivity tests:
from a Command line window, PING the IP address of the 1761-NET-ENI to see if you get a basic ICMP response.
from a web browser, enter the IP address of the 1761-NET-ENI to see if the embedded web pages are accessible.
Ethernet Devices driver the 1761 came up as unrecognized and red x, In the table I added all the IP's as listed below. If I used the ETHIP they would be recognized. I am able to ping the units and the laptop. But still not able to connect to the ML1500 thru the 1761 for programing. What or do I have to set up in the message routing table in the 1761 config utility, does this need to be configured also to connet thru rslinx to the ML1500 processor? I used these IP addresses laptop 192.168.1.250, 1761-NEt-ENI 192.168.1.10, and a second 1761-NET-ENI to 192.168.1.11 all three connected to a switch, all three I can ping OK. The 1761 are ver D all set for Auto config and the proper cables connected to channel 0 and 1.
Thanks for any insight
Since you can ping it, that is a good sign, but you should still try Ken's advice and try to access the built-in web page.
You should not need to set up the messge routing table to use it with RSLinx/RSLogix.
You might try setting the ENI serial baud rate to the actual fixed baud rate instead of auto. I have only seen one (out of about ten) net-eni modules give trouble with it set for auto, but it is worth a shot.
You might also try shutting down RSLinx and restarting it.
Hi I wrote a program in some time ago in Logix 500 v4.x (I think) using a MicroLogix 1500 (Series B). The customer has blown this PLC so I...
2,066
204
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
101
So I have a sort of unique situation where I'm wanting to run a PF755 from the IO and over ethernet. Of course, this comes with it's own set of...
321
Hi all, My ethernet port on my laptop recently broke and I was hoping to just use a usb-c dongle in the mean time to go live on my PLC until I...
479
