Micrologix 1100 Series A??
wlr3m4
Oct 2017
Saint Louis
28
I have a few previous PLCs that are installed which say they are Micrologix 1100 Series A PLCs but does this mean they are 1763-L16AWA or 1763-L16BWA??
You can't tell from the software which model you have in the field. Those part numbers as well as others are legitimate and often followed by a backslash and then the revision number.
So 1763-L16AWA/A would be a series A, 1763-L16AWA/B would be a series B.
The first character you see after the number is usually referring to the type of voltage used to power the unit.
1763-L16BWA is powered by 24vdc, 1763-L16AWA is powered by 120/240VAC.
I using a HSC:0 with no problem with a encoder, but I am not able to add the second channel in order to use the HSC:1. float memory is at F8:29...
969
Hi, I have a project where I'm replacing a faulty Mitsubishi FX3s plc with a Micrologix 1100. The FX3s was using a GS2107-WTBD HMI panel. The HMI...
1,117
Dear Forum Members, I'm new to the world of plcs and their respective programming. So I apologize for my ignorance, and thank you in advance for...
1,603
I am connecting via the Mini Din to Serial to USB, and cannot get the Mac Address to come up in BootPHP. I have previously tried with Ethernet and...
2,835
Does anyone know what the difference in I/O capabilities (if any) is between series A, B, C Micrologix 1100
1,678
