Micrologix 1200 1762-L24BXB Solid Fault Light
Nov 2017
New York
Hello,
I have a Micrologix 1200 1762-L24BXB PLC and as soon as I power it up with nothing connected to it, the power LED and the fault LED both go solid. I have tried connecting to it and doing auto configure but it says it cant find the baud rate or the parity. I have tried resetting power to it and it doesn't change. Pushing the comm button does absolutely nothing and I can't connect no matter what I try. I am using an Allen Bradley usb to serial adapter like I do with our other PLC and it's not working. I just want to try to communicate with it so I can see what the fault is and see if the PLC is usable. Any help would be appreciated. Thanks,
Ryan
Welcome to the PLCTalk forum community ! Sorry you've got a negative first interaction, though.
Verify that you have a good +24V DC input for the controller by measuring the power input terminals with all wiring connected; sometimes a wiring defect can pull the supply low and the controller won't boot up.
If the input power is good but you still get a solid red fault lamp, then the controller's basic hardware self-diagnostics are failing and it must be replaced.
I currently don't have anything connected to it except for the power supply input. I checked my supply and I am getting the correct voltage. I guess I will just have to replace it. Thanks for the help.
Hi all, I have a doubt, it might seems silly though. I would really appreciate it if you could describe how to do this connection. There is a...
2,831
hello guys. I m new to this blog and i dont know if there is already a thread discussed already about this plc. So i would like to start a thread...
2,435
i have the plc 1762-ow8 micrologix 1200 plc and a slave having rs 485 interface. how do i connect the slave to the plc. the slave is quasar meter...
2,940
Dear Sirs , Firstly i am new with using micrologix1200. my question is i have a 1762 IF-4 input module which is connected to my micrologix 1200...
8,489
hi ppl , i would like to get a 1762-ow 16 manual softcopy, i visited allen bradley website , but was not able to find it,plz send the link for...
2,531
