Micrologix 1200 firmware upgrade failed
SIRGO
Nov 2017
Quebec
Hello, anyone have an idea to help me solve my problem? I have a Micrologix 1200 PLC (1762-L40AWA serie C) and the PLC has lost its program for some reason that I don't know. After reading a little on the subject, I found a technical notice on the Rockwell website explaining that this problem was known for the old firmware and that it was enough to update it to resolve the situation. :geek: So I tried to update the firmware with the correct firmware downloaded from the Rockwell website and the update was a failure :oops: from the start and now my controller is at fault and I am no longer able to do anything. However I still see it in RSLinx, I restart the update, always fail. Also unable to connect with Logix500 to clear the fault. :cry:
See attached file for ControlFLASH log
Can someone be my savior today? Thank you!
SIRGO, the following RA techconnect KB might help with your issue. It's for ML 1100 but should still apply to your ML 1200.
518307 - Getting error DTL_E_FAIL, I/O completed with errors when flash upgrading a MicroLogix 1100
The sticker on the side of my PLC says it is a Series C and FRN 6. In RSLogix 500 under processor status, the OS FRN shows 0.00 and the OS Series...
3,211
Good Afternoon, I have a Micrologix 1200 1762-L40AWA Series C rev A with FRN 4 installed, I tried to update it to FRN 12 using the...
5,731
Hi everyone, I'm working on a project where I need to exchange data between a Siemens S7-1200 PLC and an Allen-Bradley MicroLogix 1400 PLC. The...
695
I have a MicroLogix 1200 that has an 8 input and a 16 output. Every 6 months-year I get a fault and when online go to error it is something like...
520
Have a bad output on a Micrologix 1200. Moved wire over to an available output, changed program to associate with new output. downloaded program...
764
