MicroLogix 1200 FRN3
optikal
Jan 2007
NA
I am looking for FRN3 firmware for a MicroLogix 1200 controller.
We had a new employee update the firmware from FRN3 to FRN11. Now our RSLogix 500 software will not work as it is incompatible with FRN11. According to Rockwell, the only thing we can do is pay for a newer version of RSLogix as the FRN3 firmware 'doesn't exist anymore'.
Anyone out there with a firmware compatible with v4.5.00 of RSLogix 500?
Any help would be very much appreciated.
If this is the only SLC/MicroLogix controller you have or ever will have, then go ahead and pursue an old firmware revision. I work for A-B and I would have a really hard time getting my hands on obsolete firmware sets. I don't even know if FRN3 can be loaded into a controller with FRN11 running.
But if you ever get a new controller, you're going to need the current software anyhow to work on it.
Either way you're going to need a favor from A-B to get this done. You may as well ask for the one that gets you into 2007 instead of keeps you in 2001.
Ask your local rep. how much it would cost for an e-connect support contract.
This should be very low cost. Then you can upgrade your copy of RSLogix to the lastest version. May cost less than the old firm ware.
Hi everyone, I'm working on a project where I need to exchange data between a Siemens S7-1200 PLC and an Allen-Bradley MicroLogix 1400 PLC. The...
773
I have a MicroLogix 1200 that has an 8 input and a 16 output. Every 6 months-year I get a fault and when online go to error it is something like...
537
Have a bad output on a Micrologix 1200. Moved wire over to an available output, changed program to associate with new output. downloaded program...
778
I need help achieving the following task: ML1200 sending 4 to 20 mA thru analog output ch0 to a DC speed controller analog input(4 to 20 mA) my...
694
Hi there I am new with this thing and i don't know how to connect Allen Bradley Micrologix 1200 PLC to Raspberry Pi using USB to RS485 in NodeRED...
2,305
