Micrologix 1200 NVRAM error
ashley
Jun 2002
Perth
58
I was downloading a program to a Micrologix 1200 when i got the message "Download failed!" The fault LED was flashing red. The error code I get is 01h which is NVRAM error. Cleared the error and the processor memory and tried downloading again. Same error. Tried it a couple of times but the error persists.
Do I have to replace the processor or is there a way out? This is a new Micrologix 1200 processor and all this happened during commissioning. Part no. 1762-L24BXBR.
Thanks.
First off a new micrologix processor will usually have the fault light flashing. (recoverable fault) in this case probably due to no project in the processor. If the comm 0 led is flashing then the processor is configured for rs 485. make sure your using a 1761-pmo2 cable. In rs linx it should be configured forrs-232 df1 device. If your NVRAM is shot then it should trigger a fatal fault. The problem may be that it cannot find the processor
Also make sure your processor type matches in your I/O configuration
Well, this wasn't the first time I was downloading the program to the processor.
I uploaded the program from the Micrologix, made some minor modifications in the ladder and was downloading again when this happened.
What I need to know is whether replacing the processor is my only option?
If the NVram is actually messed then the answer is yes. It isn't a removable chip. The reason for the above post is that I have seen those error messages mislead people.
Hi everyone, I'm working on a project where I need to exchange data between a Siemens S7-1200 PLC and an Allen-Bradley MicroLogix 1400 PLC. The...
694
I have a MicroLogix 1200 that has an 8 input and a 16 output. Every 6 months-year I get a fault and when online go to error it is something like...
520
Have a bad output on a Micrologix 1200. Moved wire over to an available output, changed program to associate with new output. downloaded program...
764
I need help achieving the following task: ML1200 sending 4 to 20 mA thru analog output ch0 to a DC speed controller analog input(4 to 20 mA) my...
681
Hi there I am new with this thing and i don't know how to connect Allen Bradley Micrologix 1200 PLC to Raspberry Pi using USB to RS485 in NodeRED...
2,288
