MicroLogix 1200 terminal blocks missing
bright676
Nov 2012
va
494
I have a 1762-L40AWA that is missing the plug in terminal input and output blocks.
Does any one know where I can get some/
Thank you.
Your RA distributor or Tech Support will have access to the SLC/MicroLogix "piece parts" list in the Knowledgebase. It has things like module doors, labels, terminal blocks, plug covers, etc. It also has directions for how to order those through the RA computer system.
They aren't cheap, mostly because of the cost of handling. But they're definitely available.
Hi everyone, I'm working on a project where I need to exchange data between a Siemens S7-1200 PLC and an Allen-Bradley MicroLogix 1400 PLC. The...
711
I have a MicroLogix 1200 that has an 8 input and a 16 output. Every 6 months-year I get a fault and when online go to error it is something like...
522
Have a bad output on a Micrologix 1200. Moved wire over to an available output, changed program to associate with new output. downloaded program...
765
I need help achieving the following task: ML1200 sending 4 to 20 mA thru analog output ch0 to a DC speed controller analog input(4 to 20 mA) my...
687
Hi there I am new with this thing and i don't know how to connect Allen Bradley Micrologix 1200 PLC to Raspberry Pi using USB to RS485 in NodeRED...
2,293
