Micrologix 1200
usterbea
Apr 2008
Ohio
I want to connect a serial RS485 input into a Micrologix 1200. I need to know can this be done? I think the Micrologix 1200 has a place for RS232 port.
Whats the protocol of this serial input?
Your ML1200 will speak (see pic below)
MicroLogix 1000, 1200, and 1500 have only an RS-232 serial port and require an RS-232 to RS-485 converter like the 1761-NET-AIC isolator.
The MicroLogix 1100 forgoes the standard RS232 handshaking pins and substitutes an RS-485 port, so you need only a breakout board, part number 1763-NC01.
As Mickey mentioned, the protocol is just as important as the signalling method.
Hi everyone, I'm working on a project where I need to exchange data between a Siemens S7-1200 PLC and an Allen-Bradley MicroLogix 1400 PLC. The...
719
I have a MicroLogix 1200 that has an 8 input and a 16 output. Every 6 months-year I get a fault and when online go to error it is something like...
523
Have a bad output on a Micrologix 1200. Moved wire over to an available output, changed program to associate with new output. downloaded program...
765
I need help achieving the following task: ML1200 sending 4 to 20 mA thru analog output ch0 to a DC speed controller analog input(4 to 20 mA) my...
688
Hi there I am new with this thing and i don't know how to connect Allen Bradley Micrologix 1200 PLC to Raspberry Pi using USB to RS485 in NodeRED...
2,295
