micrologix 1200
jim-garcia
Oct 2003
Reynosa
42
hello all
for a mistake we order micrologix 1200 instead a 1500 for control 2 stteper motors on the PTO outputs does any of you try to control 2 stteper with the 1200 if so how can use the HSC for both
any Help Great
thank you all
For those of you keeping score at home, a quick summary of the various high-speed counter capacities of the MicroLogix line:
MicroLogix 1000: One high-speed Counter (6.6 kHz)
MicroLogix 1100: One high-speed Counter (40 kHz), two high-speed Outputs (40 kHz)
MicroLogix 1200: One high-speed Counter (20 kHz), one high-speed Output (20 kHz)
MicroLogix 1400: Three high-speed Counters (100 kHz), three high-speed Outputs (100 kHz PTO, 40 kHz PWM).
MicroLogix 1500: Two high-speed Counters (20 kHz), two high-speed Outputs (20 kHz)
If you do not require both steppers to run at the same time, and the steppers are of very similar configurations, you could select which stepper is being run by the PTO using a relay.
If the steppers are very different or must run at the same time, I can't see a solution.
If it were me, I would buy the correct controller, and return the MicroLogix 1200 or keep it for another future project.
Hi everyone, I'm working on a project where I need to exchange data between a Siemens S7-1200 PLC and an Allen-Bradley MicroLogix 1400 PLC. The...
709
I have a MicroLogix 1200 that has an 8 input and a 16 output. Every 6 months-year I get a fault and when online go to error it is something like...
522
Have a bad output on a Micrologix 1200. Moved wire over to an available output, changed program to associate with new output. downloaded program...
765
I need help achieving the following task: ML1200 sending 4 to 20 mA thru analog output ch0 to a DC speed controller analog input(4 to 20 mA) my...
686
Hi there I am new with this thing and i don't know how to connect Allen Bradley Micrologix 1200 PLC to Raspberry Pi using USB to RS485 in NodeRED...
2,293
