Micrologix 1500 IO limitation
sandymax
Nov 2004
India
112
i will like to know the limitation for Micrologix 1500
AI =46 AO=45 DI = 91 DO= 92
the system is having above datapoints i am considering cusing 8 Data point modulels
Number of Modules
AI= 8 AO = 8 DI = 3 DO= 3
Can i go for Micro logix using above configuration , i am not sure but i need another power supply
thanks
Sandymax
MicroLogix 1500 controller systems can include up to 16 Compact I/O modules.
Even with 8-point analog modules and 32-point discrete modules, you will require 6 + 6 + 3 + 3 = 18 modules.
You could use an SLC, or a CompactLogix controller for a system of this scope.
With that much analog I/O, I suspect that you would also be pressed for program memory to handle all the presumed process control logic.
I second Ken's recommendation for using a SLC. There is a broader range of I/O modules available, plus more communication options.
Another added benefit is the ability to use remote I/O if required, and on-line programming. On-line programming has huge advantages for startup / debugging.
:nodi:
Maybe sandimac wants to use the PLC as a "remote IO" then program memory should be OK. If not, I would choose nowadays CompactLogix with Ethernet.
But yep, there is a limit (16 modules)in ML1500
129
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
125
Good Day i Have Micrologix 1500 LSP, and I want to get data from plc and send it through Modbus RTU slave; I have only ch0 on that plc I Order...
943
Hello folks, Hope everyone is doing fine. I got an OMRON NS10-TVOOB-V2 hmi screen last day and planning to use it with Micrologix 1500. 1. Is...
1,221
Good morning to all, I need to modify an existing PLC MIcrologix 1500 configured with a Modem on Channel 1 (DF1 Full Duplex) and an...
1,443
