Micrologix 1500 Node address
mavcosys
Jun 2007
pa
Has anyone found a way to change the node address of Channel 1 via ladder logic or writing to a memeroy location configured as a DF1 half duplex slave? It is a real pain to have to download a program just to change node address.
I don't know of a way to change the node address of channel 1 thru ladder code. But you can change it online, no download required.
I did this thru channel 0 ( very quick). I also did it thru channel 1 ( configured for DF1 slave with RSlinx configured for DF1 Master. It did it but very slow.
146
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
145
Good Day i Have Micrologix 1500 LSP, and I want to get data from plc and send it through Modbus RTU slave; I have only ch0 on that plc I Order...
957
Hello folks, Hope everyone is doing fine. I got an OMRON NS10-TVOOB-V2 hmi screen last day and planning to use it with Micrologix 1500. 1. Is...
1,229
Good morning to all, I need to modify an existing PLC MIcrologix 1500 configured with a Modem on Channel 1 (DF1 Full Duplex) and an...
1,455
