Micrologix 1500 to Cognex via NET-ENI
tspisak
Aug 2005
Corning, NY
72
Does anyone have an example of a ML1500 connected to a Cognex 5100? I'm getting conflicting info from Rockwell saying it only can be done with a SLC5/05.
My application is to trigger the camera, get a angle number back along (along with a pass fail signal via breakout board) then rotate the part and trigger again until it passes.
It can be done, or atleast I know a guy on MrPLC has done it. Can't help you with how but thought you may want to know the limit on cameras is 4 with the NET-ENI without staggering messages. 2 Incoming, 2 Outgoing, and 2 Either way
Kinda OT
I have done this with a ML1500, NET-ENI and DVT.
I know it’s not the Cognex but when I was going through this DVT would say “can’t you call Rockwell”
And Rockwell would say “can’t you call DVT”. Nice help from Encompass partners, huh.
Any ways, one of the keys to my solution was the version of the NET-ENI, version A would not work while version C would.
All of the examples where SLC not Micrologix. I've heard that you can use CIP485 but the communication is only one way that why I would like to see a real example for ML and Cognex.
129
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
125
Good Day i Have Micrologix 1500 LSP, and I want to get data from plc and send it through Modbus RTU slave; I have only ch0 on that plc I Order...
941
Hello folks, Hope everyone is doing fine. I got an OMRON NS10-TVOOB-V2 hmi screen last day and planning to use it with Micrologix 1500. 1. Is...
1,220
Good morning to all, I need to modify an existing PLC MIcrologix 1500 configured with a Modem on Channel 1 (DF1 Full Duplex) and an...
1,443
