MicroLogix 1500
powersoff
Nov 2010
Midwest
Hello,
I am using a Micrologix1500 1764-24AWA and would like to add 3 expansion I/O modules.
(1)1769-OA8
(2)1769-IQ16
For some reason I have it in my head that if I add more then 2 expansion I/O I need a additional power supply.
Is this superstition on my part?
Thanks for any replies.
FYI depending on what series processsor/base you can have upto 16 modules. and you could also add a second rack with expansion PSU.
when you get the modules it says on the side what they draw from the 5v bus. and also from the 24v external supply you give them.
i do not have a processor/base to hand so i could not say if it tells you on that what the maximum draw is for the bus.
rob
i wasnt suggesting you need a second psu just an FYI if he ever wanted to expand over the maximum permissable current.
and yes burnie you are correct it auto configs the modules and gives you a warning in the dialogue box when you exceed the maximum current draw, but saying that we have a 1500 bxb which has about 10 16 point input and output modules and when i connect to it, it always warns me that it is exceeding the maximum but it never has any problems and it came from the US like that
rob
105
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
121
Good Day i Have Micrologix 1500 LSP, and I want to get data from plc and send it through Modbus RTU slave; I have only ch0 on that plc I Order...
930
Hello folks, Hope everyone is doing fine. I got an OMRON NS10-TVOOB-V2 hmi screen last day and planning to use it with Micrologix 1500. 1. Is...
1,215
Good morning to all, I need to modify an existing PLC MIcrologix 1500 configured with a Modem on Channel 1 (DF1 Full Duplex) and an...
1,439
