micrologix 1762-IF2OF2
mikey431
Feb 2007
TX
I have a weird problem on the micrologix mixed module 1762-IF2OF2. What i tried to achieve is getting 4-20 mA to input and get same ( or almost closed) signal at my output.I have 4-20mA signal to simulate input. When I have 4 mA at the input , i have 3.8 mA on the output but it getting worse. when i have 14 mA at input , i have 13.4 mA on output and when i have 19.99 mA at input ,i got 18.9 at output. I am not sure if any of you had this kind of problem before...
Post your program file (.rss file).Zip it then post it if you can. (save it while online with a live input)
Then someone here can look and see how you have your card set up and scaling for output.
The micro logix family tend to scale there analogs across 0 to 21 mA or 4 to 21 mA and the values you are quoting tend to indicate that this is what may be happening.
The sheet that came with the module should be able to guide you on this.
hai
check the scaling.
So I got my ML1100 up and running last night, and tonight Im trying to connect an analog in/out module 1762-IF2OF2. The problem is that the green...
2,258
With the ML1100 being a Legacy product, this is something of an academic discussion. I have an ML1100 with two expansion modules - 1762-IF2OF2...
867
I have a Micrologix 1400 with an 1762-IR4 RTD. I use it to read airbag resistance on seats on an assembly line. I am often getting into a...
1,207
Hey guys I 'm having problems getting a valve to move that has a DVC6200 actuator connected to it via a MicroLogix 1762-OF4 PLC card. I can move...
18
5,507
Hello! I am new in this field, and I have a task to wire inputs/outputs to MicroLogix 1100 1763-L16BWA Ser A Rev C with its Expansion Unit...
1,663
