MicroLogix 800 Jump instruction
I am writing a large 850 program right now. If you right click on a rung and select Add Label, then click in that label and give it a unique name, you can insert a Jump and at the top of the Jump click in it and it will display all of the labels for that routine.
And I am thinking you can use indirect addressing if you use the same method I found for Control Logix using a variable string of the tagname and a message instruction to itself: http://www.plctalk.net/qanda/showthread.php?t=105602
Hello, I have machine that's currently running a Micrologix 1400 PLC controlling an AB Powerflex VFD via Ethernet/IP. We want to replace the VFD...
508
Hi all, I had a setup with 2 Micrologix 1100 connected to a Panelview C300 over DH-485. I was mandated to upgrade the HMI, and proposed to...
891
Hello, I have a MicroLogix 1200 controller that I'm trying to get to communicate with a PV 800 (CAT 2711R-T4T). This mostly likely means that I...
2,497
First of all Hi, nice to met you all. I have a problems trying to control my PLC's (1762-L40BWA ser. C and 1763-L16DWD ser. B) with the Panelview...
5,063
Hello Friends I have a PanelView 800 (2711R-T7T) connected with a Micrologix1400 (1766-L32BWA) and an output module (1762-OW16) I have done some...
3,757
