MicroLogix PWM function
Houdini
Sep 2004
Windsor, Ontario
I am looking to utilize the PWM function of the 1766-L32BXB. I am actually looking to get a 5V PWM out of the controller but I was told that the PWM only uses 24VDC for its output. Is this true?
Does anyone know how I can get a 0-5VDC PWM pulse train out of a micrologix controller? I guess that would just be like a TTL signal with PWM.
Thanks!
Outputs 2, 3, and 4 on a 1766-L32BXB controller have the fast FET output circuitry on them that can be used with PWM or PTO functions.
But the FETs are designed for 24V nominal voltage input. The listed range is -15% / +10 %, so basically 20.4 to 26.4 volts.
I've never tried to run it at 5V DC. It certainly is unlikely to hurt anything, but it's not designed to work at a voltage that low.
The VDC2 power input terminal on the 1766-L32BXB controller provides the source voltage for Outputs 2 through 7. If you connected only 5V to it, you would not be able to use any of those for conventional 24V output functions.
You may be able to use an interposing solid state relay/transistor setup to step your 24V PWM signal down to 5V.
Vdc2
Yea, not sure about the 5VDC on the output. I don't like the idea of having to give up 6 outputs to do this. I didn't know the common was attached to that many output channels.
I can try the solid state interposing relay idea. I need to check to see if the SSR will switch at 100Hz. I assume I can just do a voltage divider to get down to my 5VDC instead.
Hi, i'm kind of new on programming with RSLogix, i've read a lot of documentation about my problem, but i just can't fix it... I want to generate...
5,220
Hello, i am beginer to pwm control and I have a project coming up that requires pwm control of 3 solenoids. Would the micrologix 1400 be capable...
1,171
I have a couple of questions regarding the PWM output on a Micrologix 1400 BXBA. The 20 KHz output shown in the attached photo is being fed to a...
1,841
in micrologix 1400 we have to enter duty cycle to get particular duty cycle.But i want my duty cycle changes according to values coming from pid...
2,632
I have a ML1400 BXBA. I wire the 24V to th VDC2 and 0V to the Com2. And I tried to produce a square wave of 50% duty cycle with frequence 100Hz...
4,151
