Micrologix RS232 Voltage Swing
alphav
Supporting Member
Sep 2007
Ontario
35
Hello,
I am trying to connect my PLC to a Crystalfontz LCD module
What is the RS232 Voltage swing for a Micrologix 1400, or any Micrologix for that matter?
Thanks,
gerrysc
Thanks for the reply.
Since the Micrologix is using a 24VDC supply, can I assume that the voltage swing will be about +/- 12V ?
If your Crystalfontz LCD module has an RS232 interface, then just connect it up....
If however, your Crystalfontz LCD module has a "Logic Level Serial" interface, you will need to convert the RS232 level signals to "TTL Level" of 0 to +5V. You might even need to invert the signal as well.
Best bet is to use a module with an RS232 interface...
What part number is your Crystalfontz LCD module ??
The Crystalfontz part number is CFA533-YYH-KS.
I know that they have models using RS232 0-5V (TTL logic), but this one should have
RS232 full voltage swing.
Thanks,
gerrysc
I concur, that model number has an RS232 interface that will connect directly to the MicroLogix RS232 port....
hello can anyone share with me the diagram of working cable to make the comunication beetwen plc micrologix 1400 and zebra printer trough rs232 or...
6,327
Sorry for the question, but after a discussion and betting with an automation colleague, there was a doubt. In the micrologix manual it says...
3,230
Okay here we go. I am new to this and I need to know the easiest method to mate an Micrologix 1100 to and Automation Direct with RS232. I have a...
2,821
I am having trouble with communication between my micrologix 1000 and my magelis HMIGTO5310 touchscreen i have added the allen bradley df1 driver...
1,487
I am trying to communicate from a Micrologix 1400 chan 2 to a SC2124M scanner via modbus rtu. I have taken a straight through cable with RS232 on...
2,783
