Micrologix Series ?
mrowen
Dec 2003
28
Hope this isn't too trivial of a question. I am relatively new to actually programming plcs and have a need to play around a bit. Looking at picking up a micrologix unit off ebay. I notice that there are different "series" units such as "c" or "e". Can anyone explain or point me to a website that describes the differences. Or is it just a older versus newer stuff.
Also, are there any places to buy (online would be nice) the micrologix plcs for something less than the list price posted on AB's site?
Many thanks,
Mike
A-B sells a 10-point MicroLogix 1000 controller for $99 and the software that programs it (and only the 10-point controller) is free. So that's your low-dollar way to get into A-B controllers.
To answer the original question, the Series Letter on an A-B product changes when the function of the device or it's actual hardware design changes. In the MicroLogix 1000 product line, the only important change was in Series C, when the DF1 Half-Duplex protocol was added to the controller. Most folks don't use that feature except for remote telemetry applications.
One more thing; nobody pays list for A-B controllers. It's an anachronism from the Nixon days that A-B list prices are higher than the prices you'd pay even over-the-counter at a dealer. That's one o the reasons those snarky Automation Direct ads can show such startling disparities in list prices; the A-B list price is at least 20% higher than what you'll really pay, even as a retail customer.
Unless A-B is dominant in your particular market, buying a used MicroLogix 1000 and RSLogix 500 Starter ($500) is slightly steep to learn about PLC's in general. I'm sure some other members will post their best "starter" controller and software setup.
I am going to go with Ken but in another aspect. Since you are in the US and it seems you are familiar with AB already. I gathered this because you were looking at Micrologix. Get the $99 10 point version, the software covers enough ground to familiarize you with RSLogix500 and its free.
Yes there may be other brands that can show a better price comparison but if you are working in an environment that already uses AB then its good to learn on AB.
I'm not completely new to plcs, just never been involved with actually developing large programs. I already picked up a 1000 with 16 I/O for next to nothing on ebay. It is a series E. No problems what so ever. Just curious what the differences were in the different series since I now want more I/O and am looking at getting another unit. As for software, I already have that.
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
148
I using a HSC:0 with no problem with a encoder, but I am not able to add the second channel in order to use the HSC:1. float memory is at F8:29...
979
Hi, I have a project where I'm replacing a faulty Mitsubishi FX3s plc with a Micrologix 1100. The FX3s was using a GS2107-WTBD HMI panel. The HMI...
1,131
Firsts of all to make it clear I am novice at programming and controllers. I was called to a costumer who has four machines that do identical...
1,543
Hello. I am having an issue trying to read data from the flow sensor model FL-608 (Digiten) in my micrologix 1400. I read that i have to use a...
1,886
