Micrologix1200 as an IO device to Citect Scada
akosimalakas
Aug 2020
Manila
How to check the communication between the Micrologix1200 to Citect SCADA. I use PLX51-DF1-ENI router to communicate in scada.
I tried to use protocol ABMLXEIP but still not having data from plc. I can remotely connect in plc using RSlogix500 by ethernet.
I have a micrologix 1200 that will run one of three different timing sequence, depending on which input is triggered. I'm trying to find the best...
3,462
I have a micrologix 1200 and I am trying to get a barcode scanner to talk to the COM 0 port. I know the scanner baude rate is 9600 because I...
1,789
Good day all. I have a some MAC bullet valve catrtidges (BV210A-CA1-00-BEH0-CTC). They control vacuum for suction cups that pick up various...
1,623
Can I communicate to a Micrologix 1200, going through a Panelview C600? I have this machine made by SIDEL that has a Micrologix 1200 talking to a...
1,495
Good day all. What is the exact software that is required to program the MicroLogix 1200. I know it is RSLogix but what type. They have...
13,877
