MicroLogix810 Sequential Programming
PeteCoster
Jul 2014
Honiton
Hi everyone
I am very new to PLC programming and need some advice, I am trying to program the MicroLogix to run a test bed for me. The design so far consists of an on/off on I00, the rest is time controlled outputs. I need a 16 minute cycle to run continuously with this split into 4 smaller 4 minute segments for each of my outputs. Each output is to run for 1 minute, then off for 3 minutes before the next output runs.
This is accelerated testing that I am carrying out on a pump and 4 items of control equipment and so the 3 minute downtime between runs is essential.
I have a blink timer running every 4 minutes to give me an output to a sequential output block, the output block and blink timer run perfectly together. I just cannot figure out how to get from the sequential block with a useful output. Its output is shown as a word output and so was hoping to use an ANY_TO_BOOL block to activate a BOOL output and thus an off delay timer of 60s.
Can anyone help with the missing link?
Regards
Confused.com Pete
Much obliged Doug, this is the sequencer that I am using. How do I create an output from this sequencer? The help file gets me to the setup and it runs fine, I cant work out how to link from the output of this sequencer to a time off delay and then my coil output.
I've never used the 810. I just found that bit of info poking around the Rockwell site. I considered downloading the software to see how it might be done but there's that whole registration thing (n).
Sorry.
Hi there, We have a system at a water treatment plant where large raw water tanks feed into the plant that's all on the same level. At high tank...
18
3,766
Hi, I started off my career in PLC programming doing water/wastewater on AB around 20 years ago, but then moved overseas a few years later and...
57
12,071
It appears to me that Logix is improperly executing sheets of an AOI in sequential scans instead of the same scan as the main program. To test...
1,678
Hi, is it possible to read the name of the steps in an S7 Graph sequencer? In the parameterinterface there is, for example the parameter #S_NO...
21
7,199
Hi All, is there a way to incorporate SFC with HMI in some way, in order to represent missing conditions for next step. Something similiar...
974
