Migrating Allen Bradely -> Siemens (SLC500 to S7)
mad4x4
Mar 2009
ST CYrus
363
Can it easily be done ?
We have a legacy project written on Allen Bradly 1746-l542 with Several racks of some on an extension rack and some on A Fiber optic Network
What we would like to do is migrate this over to a modern PLC preferable a SIEMENS S7 -300 or an S7-400 ( We have loads of these spare)
Andy
Can it be done? sure. Is it easy? not exactly. At the base, some logic will translate over (contacts and coils are contacts and coils), but most system instructions will require complete reworking. The tags will also need to be remapped. You CAN use DBs to emulate the data files in a SLC500, but you probably don't want to.
I'd 2nd the recommendation for 1500. I'd be wary of trying to frankenstien a system together out of existing spare parts, although it could be done.
Depending how the extension racks are set up, you might be able to use a gateway to control them and leave them in place, or might need to change them out for new IO on PN, and install Ethernet cables for the comms.
Siemens has a software that converts the code from Rockwell to TIA Portal. It is absolutely awful and ten times worse than something written new, but should do the exact same thing as the SLC.
252
Has anyone migrated Proficy Historian data to a new server? I followed the guide to move all the data over, but when I run the utility, it stops...
70
We are upgrading our FTV ME v8.1 program to SE v12. Is there any way to migrate the alarm tags (about 600ish) from ME to SE. The import / export...
852
I just want to get others thoughts on what is the biggest obstacle one faces in migrating to a newer system? For me with the few systems I have...
17
4,151
Hi all, I'm working on migrating some old Sinamics S120 drive units currently integrated in Step 7 5.6/WinCC Flexible 2008 RT to TIA Portal V14...
3,409
